Case-O-Matic Question Again
Hard Knocks
09-24-2006 10:30:19
On the 800 Case-O-Matic does all the trans,rear and front section share the same oil or are they separate.How much fluid do they hold?Fired the 800 up yesterday after I got it home and it ran for about 1 minute before it blew the hose running from the pump on the side of the housing
to the bottom of the radiator.The fluid appeared to be motor oil.Shouldn't it have hydraulic oil in it?Any suggestions/advice welcome thanks!
c hess
09-24-2006 10:46:20
 Re: Case-O-Matic Question Again in reply to Hard Knocks, 09-24-2006 10:30:19
It is separate an holds 4 gal. Over time it will turn colors an look somewhat like motor oil. I would use Case hydraulic oil as first choice. There is also a filter in system that you remove on right side close to temp inlet. It has 4 9/16 head bolts on it .
