SC Case multiple problems--brakes first.
gerald kern
09-04-2002 12:22:46
Just purchased a 1948 SC. It starts great but runs rich with black smoke(address that later). One brake drum missing the other just slips past(disc type). Took it apart and disc pad almost down to the rivets on both sides--total thickness about 1/2 inch. Is that my problem--not enough thickness? How thick is a new lining, ordinarily? I have no manual yet and nothing with which to compare, so am in the dark here. Appreciate advice on this. Gerald
C. Amick
09-05-2002 10:17:40
 Re: SC Case multiple problems--brakes first. in reply to gerald kern, 09-04-2002 12:22:46
You should probably have the discs relined, but I doubt that is the real problem. I just rebuilt the brakes on my 1949 SC. It is a ramp ball type disc brake. I had the discs relined, but my problems were more severe than that. There are two sets of steel balls in each brake. There is a set of 4 and a set of 3, if I remember correctly. If the balls are rusty, the brakes will not work. Get some steel wool and shine them up. One of the plates that the balls are sandwiched between on my tractor were broken. I don't know whether or not this is a common problem. My tractor has really good brakes now.
Gerald A. Kern
09-05-2002 16:45:18
 Re: Re: SC Case multiple problems--brakes first. in reply to C. Amick, 09-05-2002 10:17:40
Thanks for your reply. I have had it apart and as you say there are steel balls..Looks like they have white grease on them--Don't know if they should. Should I clean them up and take all the grease off? I've tried moving the ring adjuster gear, but does not seem to help. Just ordered another used brake assembly--mabe that will give me a clue as to how this is supposed to work.
C. Amick
09-06-2002 13:33:54
 Re: Re: Re: SC Case multiple problems--brakes first. in reply to Gerald A. Kern, 09-05-2002 16:45:18
I don't think the steel balls should have grease on them. I know I didn't put any on mine. I think that the balls are supposed to roll out of their pockets when the brakes are applied. I think the grease will cause them to want to slide instead.
Mike Schotte
09-04-2002 12:39:00
Gerald,
I look forward to seeing what replies you get. Brakes are the next thing on my list for the '49 SC. (It's time to stop relying on the belt pulley brake shoe!)
-Schotte
Baggsy-wy
09-04-2002 20:51:05
 Re: Re: SC Case multiple problems--brakes first. in reply to Mike Schotte, 09-04-2002 12:39:00
New brakes will make a he11uva difference...part number A3010AA. Case dealer has 'em, $73.49 @ a couple years ago, Don L ( 507 433-0073 ) should have 'em too and might have a better price. Check the seal behind the brakes in the cast for leaks at the time too. Gotta drain the rear end but easy to put in at the same time...keeps the brakes dry which adds to the 'Stop-um'.
Gerald
09-05-2002 17:21:56
 Re: Re: Re: SC Case multiple problems--brakes first. in reply to Baggsy-wy, 09-04-2002 20:51:05
Thanks for your comments. I'm assuming the part # you mentioned is for the disc only and not other parts of the assembly. Also should there be grease in the ball bearing of the pressure plate as it seems to slip past when the brake pedal is pushed. Sometyimes it will grip when pushed at a certain angle. Also there is play in the pedal anchoring and the linkage seems to be a homemade jobber. Mabe that is part of the problem. Appreciate any comments you might have.
