Slipping L clutch
Buck
09-03-2002 13:07:21
On the "L" case the overcenter dogs on the clutch do they get worn to where they go to far overcenter and lets the clutch slip??? Can you run a button clutch ??? Can you make it a dry type clutch???
Allan
09-04-2002 21:51:34
 Re: Slipping L clutch in reply to Buck, 09-03-2002 13:07:21
The clutch is adjustable. Remove the rectangular "hand hole" cover and you will see a pin on the outside of the dog assembly. You have to pull the pin out and rotate the complete engage dog unit clockwise a little to tighten it. It is on threads. You only need go a couple or three holes unless it's badly fried. You'll have to ask the puller guys about button clutches, but I suppose they can use an old plate and put the pads on them.
