LA #2 spark plug abnormally oilly??
robert
08-31-2002 18:16:01
Compression is 75lbs across all 4 cyl.(warm engine). #2 plug is very oilly Engine has even power.Can oil be running down Valve guide,or what do you think.Doesn't seem to foul plug but want to cure this. Is 75Lbs Good?? This is after a good hour tillage work out.To rule out cronic stop start scenario. No smoke either.thanks.
Allan
09-02-2002 20:25:58
 Re: LA #2 spark plug abnormally oilly?? in reply to robert, 08-31-2002 18:16:01
Yes, Oil can be sucked in around a loose intake guide, but a stuck oil ring could cause a problem as well.
