Pressure plate thickness ?????
Eddie in KY
08-31-2002 17:46:46
Can anybody tell me what the minimum service limit is for a Borg & Beck pressure plate on a DB 885. I have one that will need machining and can't find a service limit amount anywhere.
Elmer
09-01-2002 04:51:10
 Re: Pressure plate thickness ????? in reply to Eddie in KY, 08-31-2002 17:46:46
I have never machined them. I have always replaced the plate when rebuilding them. You need to make sure you set the finger height at the proper level or they will move too far back and you will lose pedal travel clearance as the disc wears. I used to buy Hy-Capacity rebuilt pressure plates, but got real sick of going back into the tractor to replace poor quality rebuilt pressure plates. The clutch i priced to you was the German built "LUK" clutch. So if you buy somewhere else "BEWARE".
Eddie in KY
09-01-2002 14:00:00
 Re: Re: Pressure plate thickness ????? in reply to Elmer, 09-01-2002 04:51:10
What you priced me was either a complete assembly or a very expensive plate. I didnt need the assembly, I just need the plate. No one would price me just the plate. I got a good used one that just needs a little cleaning up. The manual tell me how much to take off when machining but it doesnt give a minimum limit on thickness.
Elmer
09-01-2002 14:14:44
 Re: Re: Re: Pressure plate thickness ????? in reply to Eddie in KY, 09-01-2002 14:00:00
I priced a comlete assembly to you. To buy just the plate is almost the same money. The manual does not give a thickness spec. If you have to resurface it i would not go too much past 10 to 15 thou. The laycock in the bigger Browns state only 5 thou. max.
