SC 1941 PTO shaft removal
Mike G
08-31-2002 14:20:30
I just purchased a 1941 SC, but it has a bent PTO shaft, How would I go about removing & replacing the shaft..Also is there a place to buy
a new or used shaft.
Help
D Smoker
09-01-2002 06:55:48
 Re: SC 1941 PTO shaft removal in reply to Mike G, 08-31-2002 14:20:30
You have to remove the transmission cover, which means also the fuel tank, hood, and everything else you have to, to get the cover off. The shaft runs across the top of the trans. You need to have the cover off to deal with the gear on the front end of the shaft. I don't know if you can get a new shaft or not there are a couple variations of that shaft. I have one out of a 44 with the power lift, if you have a power lift it might work. You can't get the trans cover gasket from Case anymore, so you have to cut one or use a tube of gasket maker. It's a pretty straight forward repair it just takes some time and you hav to remove a bunch of stuff to get to it.
