DC timing
Nedd
03-13-2006 11:27:15
Got the 49 DC running again, but realized it has a DE motor in it. My mag timing must be slightly off. How do you check it and what should it be? Went to drive it around a bit and it pulls down too much when going into 3rd and 4th. Doesn't got too hot but didn't have it running for very long. But it sure sounds nice, love those old Cases.
Paul f
03-13-2006 13:26:31
 Re: DC timing in reply to Nedd, 03-13-2006 11:27:15
Open the timing inspection hole and rotate the engine until the letter "D" stamped on the flywheel is centered in the inspection hole. At that point teh impulse coupling shouod release in the mag (snap). If not loosen mag and move it until it does. Manual gives a better longer explanation.
Paul f
03-13-2006 13:29:15
 Re: DC timing in reply to Paul f, 03-13-2006 13:26:31
Forgot to add that the D stamp may not be real noticeable...My VAC must have been made on a Friday and the guy was too tired to swing the hammer very hard....it is the faintest timing mark I have ever seen.
