Steering wheel restoration advice
Mike Schotte
08-30-2002 18:36:50
Hi All,
I think I'm going to use the holiday weekend to finish up the replacement steering wheel and sterring column for my SC.
My question is with regards to the rubber on the steering wheel. I was lucky enough to get an original wheel that still had all of the rubber grip on and in really good shape... just small surface cracks and a few larger cracks around the spokes.
After I hit it lightly with a wire wheel, all of the powdery surface rubber has been removed, and I'm left with a nice (hard) rubber grip.
The question is this- how should I treat this rubber when I repaint the steering wheel? I could do like an automotive wheel, and grind the cracks into vee shapes- apply bondo and sand smooth. However, that would mean painting over the rubber with black paint when I'm finished. Not sure how that would feel and/or hold up on the grip part.
Any advice would be appreciated. Should I paint the grip to protect it, or apply some type of other coating over the rubber?
Thanks, -Schotte
Steve Staysko
09-01-2002 11:35:52
 Re: Steering wheel restoration advice in reply to Mike Schotte, 08-30-2002 18:36:50
If you want a first class inexpensive steering wheel restoration send your steering wheel to:
Minn-Kota Repair
Steering Wheels Restoration
38893 - County Highway 12
Ortonville Minnesota
56278
320-839-3940
At a cost of $68.50 and shipping $12.50 del. 6-8 wks. When they finshed restoring the rubber on my Case steering wheel it look better than when it was new..... .
Lucas
08-31-2002 18:20:28
If you want the steering wheel to be the same when you are done use PC-7. It is a two part epoxy that will stick to anything and looks good. Put primer on the steering wheel and paint it, then clear coat it. Did this on my SC and it looks great
Gary Quimby
08-31-2002 06:53:05
Mike: I was told on another site that you knew information on LeRoi engines. My father-in-law just aquired one Model#44068 believed to be the power plant for an old carousel. Do you have any information about this engine or can you tell me where to find any?
Thanks
Gary
Not Me! (Mike Schotte)
08-31-2002 07:06:06
 Re: Re: Steering wheel restoration advice in reply to Gary Quimby, 08-31-2002 06:53:05
Just for the record (since people e-mail me all the time about this) - I don't know anything about the LeRoi engines.
I just picked up a swap meet Zenith 62AJ10 carb on the chance that it might work on a Case DC. My name will turn up any time somebody does a search for LeRoi on the site.
Good luck to y'all... it sounds like you'll need it.
Now- can anyone help me with my steering wheel?
-Schotte
John Ne.
08-31-2002 09:56:00
 Re: Re: Re: Steering wheel restoration advice in reply to Not Me! (Mike Schotte), 08-31-2002 07:06:06
Why not fill the cracks with silicone RTV if you want to retain the rest of the rubber grip?,,if not, I'd just paint it. john
