DC problem
Scott
08-28-2002 19:15:17
Got a 39 DC with a miss on #1 cyl. Compression is 60 on all cylinders except#3 at about 52. Sounds low but they are consistent. I sprayed ether around intake while running and made no difference so I assume no leaks in the manifold. Anyone have any ideas?
whip
08-29-2002 18:40:02
 Re: DC problem in reply to Scott, 08-28-2002 19:15:17
Scott, Compression seems a little low, I believe you should have 90 plus pounds. Do a leak down test on each cylinder and see how much blow bye you have. Or you can bring each cylinder
to TDC ON COMPRESSION STROKE,add compressed air to the cylinder and listen for air leaks in the intake ,exhaust,oil pan area,and radiator for bubbles [that the radiator cap off before you put air in the cylinders].If you know what cylinder it is and you think it is the plug change that plug to a now good cylinder. hope this helps
joecool
08-29-2002 05:44:39
what kind of plugs are you using? IF champion then that is problem, install autolites. I had same problem.
Zach
08-29-2002 18:40:56
 Re: Re: DC problem in reply to joecool, 08-29-2002 05:44:39
we use champions in our dc never had a problem been in there for 9 10 years we use champions in our 400 430 and don't have a problem used them in our L. don't have a problem.
Zach
08-28-2002 20:25:58
howd the spark plugs look?? wires?? need new cap rotor if it has a dist.
Scott
08-29-2002 04:22:44
 Re: Re: DC problem in reply to Zach, 08-28-2002 20:25:58
With the spark plug out of the cylinder it has a good spark. I don't suspect a firing problem. First thought was intake leaking but that seemed ok.
jal-SD
08-29-2002 06:16:17
 Re: Re: Re: DC problem in reply to Scott, 08-29-2002 04:22:44
I'd suggest that you pull the valve cover & see if valves are working. Once in a while DC's & SC's have a problem with valve springs breaking. That could be your problem. (My $0.02 worth. jal-SD)
Scott
08-29-2002 08:05:12
 Re: Re: Re: Re: DC problem in reply to jal-SD, 08-29-2002 06:16:17
Already done that. Set clearance at .018 as recommended. I wonder if there could be an obstruction in the intake manifold such as a muddobbers nest. I'll pull the manifold off and see. Thanks for the help.
