Need help aint found a
shan
08-26-2002 08:57:48
I&T book for my 1956 401 case how do i check the fluid for the 3 point and what does it use? any ideas on finding a book ive been to barns and nobels store by me and they dont even list it in there computers??? thanks again shan
Pat T
08-27-2002 03:38:02
 Re: need help aint found a in reply to shan, 08-26-2002 08:57:48
Hydraulics hold 10 1/2 qts ATF type A or HyTran type tractor fluid. Drain plug is in front of drawbar swing bracket on bottom of hyd housing. Fill level plug is 1/8" pipe plug about 1/2 way up hyd housing on right side. There is a reusable filter to the right and below the pto behind the triangle shaped cover in hyd housing, swish in diesel fuel to clean. Handle carefully, only pressed paper. Owner's manual has good stuff on this too, be worth getting while you're looking for the I&T book.
Pat
Larry
08-26-2002 14:00:21
n/m
Terrance
08-26-2002 11:08:05
If you contact me off list I can scann the pages of the Case shop manual and send them to you through email.
good luck Terrance
