It wont come apart, What am I missing ????????
Eddie in KY
08-23-2002 17:33:34
Its a DB 885. I am trying to split this thing to repair the clutches. I have all the bolts that I can find out, but it just wont come apart. The clutch cover is loose and all the bolts I can find that hold the motor to the trans are out. I have even tried a come-along to my truck, it just wont budge. What am I overlooking ???
Jimc
08-24-2002 16:03:29
 Re: It wont come apart, What am I missing ???????? in reply to Eddie in KY, 08-23-2002 17:33:34
Hi Eddie You can`t split an 885 to do the clutch, as the clutch cover goes down the back of the flywheel. You need to take off the fuel tank ,steering box, gearbox lid and then the clutch cover, then you can split it or if you further remove the pto case and pull out the pto drive shaft you can push forward the muff coupling on the gearbox and lift out the full clutch assembly without spliting the tractor. If you need further help just ask. Regards Jimc
Patches
08-24-2002 18:12:57
 Re: Re: It wont come apart, What am I missing ???????? in reply to Jimc, 08-24-2002 16:03:29
Take the cover off the bellhousing there should be bolts on the inside that must come out.
Elmer
08-23-2002 18:43:21
Check up under the fuel tank, there should be two 3/8 bolts into the top of the clutch housing that go into the engine. I will try to price out parts to you on monday. I am sure i can direct ship them to you.
Eddie in Ky
08-23-2002 19:11:02
 Re: Re: It wont come apart, What am I missing ???????? in reply to Elmer, 08-23-2002 18:43:21
yep got them too, there are 4 under the trans, the 2 you mention, and 2 little 5/16? bolts in the bottom corners of the trans bell housing. I dont have any idea what they would hold, but they are out too. It just aint budgeing.
Elmer
08-24-2002 05:21:41
 Re: Re: Re: It wont come apart, What am I missing ???????? in reply to Eddie in Ky, 08-23-2002 19:11:02
Memory has got me down today. I know of an 885 not too far from here. I'll take a drive over and look it up and down. Will get back to you.
Elmer
08-24-2002 18:56:29
 Re: Re: Re: Re: It wont come apart, What am I missing ???????? in reply to Elmer, 08-24-2002 05:21:41
Sorry did not get the time to get to the 885 today. There should be some bolts that bolt horizontal into the side of the transmission housing to the clutch housing. Something tells me you may have to feel around inside the clutch housing through the inspection hole. It has been a while since i had one of those apart. They were a trouble free tractor if well maintained. There is a 770 not far from here which is basically the same tractor has 24,000 hours on it. Look around the foot throttle and cluch pedal for bolts.
