David Brown 885 hydraulic pressure
Bobby
08-22-2002 10:23:13
Just wondering if there is any way to adjust hydraulic pressure on a david brown 885? The lift on it will work really slow at idle,after checking the pressure at a remote noticed holding just about 500 psi at idle and 1400psi at 2200rpm . any info would be greatly appreciated.
Thanks, Bobby T
Elmer
08-22-2002 18:50:39
 Re: David Brown 885 hydraulic pressure in reply to Bobby , 08-22-2002 10:23:13
I would say your pump is likely worn out. Remove the pto housing and grab the gear on the pump and see if there is up and down movement. That will tell you alot whether it is wore out or not. Be sure to remove the hydraulic light switch manifold from the bottom of the pto housing or you will shear it off.
Bobby
08-22-2002 21:01:20
 Re: Re: David Brown 885 hydraulic pressure in reply to Elmer, 08-22-2002 18:50:39
Not tore it down yet but wondering if any one knows a good place to get a pump? Are they a gear or vane pump.Rebuildable maybe?
Elmer
08-23-2002 04:20:50
 Re: Re: Re: David Brown 885 hydraulic pressure in reply to Bobby , 08-22-2002 21:01:20
I have a pump in stock, they are a gear pump. Send me your address and i can quote you a price and postage. The relief valve is on the top of the hydraulic pump, they usually don't give trouble. My computer is acting up so in case you can't get an email through to me my phone number is 519 363 2663.
Bobby
08-23-2002 17:45:00
 Re: Re: Re: Re: David Brown 885 hydraulic pressure in reply to Elmer, 08-23-2002 04:20:50
Tore into it today ,pump feels great , looks new.Turned pump by hand noticed oil squirting out the back of pump between it and plate, took off pump and o ring was partially gone.I hope this fixes it.
Thanks for the info.
Bobby
Elmer
08-23-2002 18:45:49
 Re: Re: Re: Re: Re: David Brown 885 hydraulic pressure in reply to Bobby , 08-23-2002 17:45:00
Check the bore in the back of the pump where the pressure tube goes into. It could possibly have a groove wore into it. That is what causes the Oring to blow out. If it does use a piece of emery cloth to smooth it out a bit.
