Case 310B
Jim M. Gemmrig
08-21-2002 20:11:46
Im trying to find parts for this case/has 4/cyclender gas/size unknown/any hits how to find out/and where i might get engine parts.thanks
Marc
08-22-2002 07:31:48
 Re: Case 310B in reply to Jim M. Gemmrig, 08-21-2002 20:11:46
Jim,
Follow the link for an application chart and pricing for in frame and major engine overhaul kits for your machine.
Thanks, Marc
Terrance
08-22-2002 07:12:45
If your Tractor has a gas engine it is a Case 148 cu in engine ,probably the most common of all Case engines. You can get parts at NAPA or most any good auto supply store.Central Tractor,Tisco and a few other Farm supply houses also sell parts for this engine.You have to know weather it is a 148 or a 148B engine and as far as I know the easiest way to tell is by the starter bolt pattern.
148 has 2 bolts holding the starter on, the starter mounts directly on the bellhousing
148B has 3 bolts holding the starter on and it mounts on the block
It is a good little tractor and if taken care of will serve you well.
Good Luck Terrance
