Will this hand crank work on my DC-3
Chris Hibbert
08-21-2002 12:25:59
third party image
Sorry to bug you all so much (I am such a newbie to tractors)
I have a 1951 DC-3 and I want a hand crank for it.
I found one on ebay but I am unsure if it will work (the lady doesn't know what CASE it came from)
The item number is below if any of you could look, I'd appreciate it.
1760107874
Tom Railsback
08-23-2002 06:06:01
 Re: Will this hand crank work on my DC-3 in reply to Chris Hibbert, 08-21-2002 12:25:59
THis crank is for a C not a D. The D cranks are
curved to follow the curve of the cast iron grille. However, it would work on a D or DC4,
but definitely not on a DC3.
Don R
08-22-2002 20:03:41
Chris,
That crank assembly is from a D or early model DC4 with the front axle mounted under the radiator. It definitely will not work as the DC3 crank is removable, is about 2 1/2 feet long and mounts along side the seat when not in use. I hope this helps.
RobertTX
08-21-2002 12:56:11
I was also looking at that crank. I don't think it is for L or LA, but kind of hard to tell from their pictures. One thing I noticed is that the part of the crank handle that would stick out under the radiator looks kind of short, indicating possibly C rather than DC, but I am not sure. If you have a salvage in your area, you might come out better there than a "not sure" part, especially by the time you ship that heavy crank. If it helps any, I have bought other items from that seller, and they have pretty well been as represented and shipped with reasonable promptness.
Larry
08-21-2002 12:50:20
No I don't think so. I have one haning in the barn. How much will you give me for it?
Jim M
08-21-2002 15:11:07
 Re: Re: Will this hand crank work on my DC-3 in reply to Larry, 08-21-2002 12:50:20
The one in the picture looks like one for a D, DO, or a DC4. It won't work on a DC3. It uses one with a flat blade end that insert into spring loaded mechanism in the front.
Bob
08-21-2002 15:33:50
 Re: Re: Re: Will this hand crank work on my DC-3 in reply to Jim M, 08-21-2002 15:11:07
Looks like a crank from a 'C'
