Location of Serial Number on L
Tim Poland
08-21-2002 11:31:11
I just purchased a 1931? CASE L. I do not know where the serial number is located. Is it suppose to be on the tool box? If it is, mine is missing. If the serial number is missing, can I get a new serial number plate?
Thanks
Tim Poland
08-23-2002 08:51:22
 Re: Location of Serial Number on L in reply to Tim Poland, 08-21-2002 11:31:11
Thanks for the info, I looked for the serial number but still couldn't find one. The block on my tractor had been replaced at one time also.
RobertTX
08-22-2002 06:31:45
The very early Ls had a tag on the casting that holds the radiator, lower right side. I don't know how long this was done. Later they began stamping the SN on the flange where the engine mates to the transmission housing, just behind the air filter housing. Some of them have it stamped on a boss at the top of the block, left side. Look just below the No. 1 cylinder exhaust port, my 37 is like that. I think replacement blocks did not have any serial numbers on them, I have seen some like that.
Jim P
08-23-2002 05:37:34
 Re: Re: Location of Serial Number on L in reply to RobertTX, 08-22-2002 06:31:45
Your are right about it being on the lower right(from sitting on seat and facing forward) Rad. casting.(actualy the support casting) My 1929 L has it their and it was made in the very first run of L's.
RobertTX
08-23-2002 06:07:08
 Re: Re: Re: Location of Serial Number on L in reply to Jim P, 08-23-2002 05:37:34
You have a very unique tractor. I have only seen one of those that was complete. It also had a small hole in the hood with a little cup type oiler for the valve train. Can you post pictures? I'm sure many of the people that follow this board would like to see it. Thanks.
Jim P
08-23-2002 23:11:55
 Re: Re: Re: Re: Location of Serial Number on L in reply to RobertTX, 08-23-2002 06:07:08
I posted a pic I took of the L on Aug. 19 on the Tractor Photo's. If you look close you can see the plug(bolt) you remove to oil the rocker arms. This tractor was bought new in the fall of 1928 and it never went back to any dealer for anything. My Dad did all the work on it that was ever needed. In the first 20 years of its life Dad overhauled it every two years by putting in new Slevees Pistons and rings, ground the valves. He said in the thirty's it just cost 36 dollars to do it. It was put on rubber in 1938 or 9.
John H
08-21-2002 18:08:06
I believe the plate was on the tool box cover but someone more knowlegable than me with the L's can verify it. The number should also be on the block where it bolts to the transmission housing. The JICCA used to provide replacement tags but not sure if they do anymore. Give Jerry Sanders a call and see if he can give you the info. He is with the JICCA. 708-946-6801
Thanks.
