Checking Oil Level
Chris Hibbert
08-20-2002 04:52:20
I know this is a lame question but I can't seem to figure it out.
I have a '51 DC-3 and I cannot for the life of me tell how I am supposed to check engine oil level.
Any help would be greatly appreciated.
Chris
jal-SD
08-20-2002 08:27:53
 Re: Checking Oil Level in reply to Chris Hibbert, 08-20-2002 04:52:20
Chris, I think you'll find two plugs on the side of the oil pan. The lower plug was originally designed to drain off lighter oil that accumulated in the pan when using "tractor fuel". You then filled the crankcase until oil ran out of the top plug. To check oil on a tractor that only burns gas, remove the top plug-if oil comes out, you're good to go. If not, pour oil in (slowly) until it starts to drip out. Then you're good to go. At least, that's the procedure used on my SC's. I think its the same on DC's. Sorry, but I don't remember what they recommended to use in the lift on the old girls. (My $0.02 worth. jal-SD)
Chris Hibbert
08-20-2002 05:00:24
And another question. When I removed/straightened/re-assembled the PTO shaft, I had to remove the Hydraulic Pump and therefore lost the liquid. I asked the case dealer what fluid to replace it with and they sold me some transmission/hydraulic combo (pretty lightweight compared to what was in there) and now the pump is noisy when in use - should I be using some other fluid?
JD
08-20-2002 19:26:46
 Re: Re: Checking Oil Level in reply to Chris Hibbert, 08-20-2002 05:00:24
Use 80w-90w gear lube I recommend Super Tech brand
Old Iron
08-20-2002 18:01:36
The oil originally was 30 Weight non-detergent motor oil. I used some regular hydraulic oil in mine and it worked ok.
