Figure out what I'm missing !!!!!!!!!!!!!
730
08-19-2002 20:17:16
got a 1030 case with new pump, injectors, lines, powercells, timing at 32BTDC, electric fuel pump, very little blow by, 400lbs of compression, open air breather, 3000rpm's (non turbo) I HAVE NO FREAKEN POWER!!!!! My 730 gas out pulls it! Please help????? ?
Jim P
08-29-2002 21:19:24
 Re: figure out what I'm missing !!!!!!!!!!!!! in reply to 730, 08-19-2002 20:17:16
A 930 rpm's is 1600 maybe up to 1800 I believe a 1030 should not be much more. 32 degrees seems to far advanced, 25 to 27 should be about right. Make sure your rack in the pump is free. also all filters good, and good fuel flow. I had corn silage in my tank and it restricked flow. altough running lean it smoked like crazy and wouldn't pull your hat off.
JD
08-20-2002 19:39:42
I don't think its what your missing its what you need to lose. The electric fuel pump is more than likely holding pressure through your injection lines.
scott AR
08-20-2002 18:59:04
Are you getting smoke? If so what color?
Gary McKenzie
08-20-2002 06:12:25
Check fuel supply pressure. Your injection pump should be a Bosch inline type, don't have the exact spec's but you need app. 15-20 psi supply press. I'm not sure you can get that w/ an elec. pump. Also, 3,000 rpm seems far too high, should be around 2,200. Hope this helps!
