Case VAC remote hydraulic valves
Steve Lehman
08-17-2002 21:11:42
I would like to add a hydraulic valve to my VAC with an Eagle hitch so I can use a remote cylinder with it. How do you go about plumbing the valve in the line between the pump and Eagle hitch? My best guess is that you plumb from the pump to the valve's "in" port and from the valve's "out" port to the Eagle hitch. Does this require an open center or closed center valve? Any help would be appreciated.
George
08-20-2002 11:55:11
 Re: Case VAC remote hydraulic valves in reply to Steve Lehman, 08-17-2002 21:11:42
You might check the pump pressure. I think that the VAC pump only puts out 750 psi. Gives a 3" cylinder 2 1/2 tons push.
My pump went bad and I replaced it with a combine pump. I used the powersteering stage for the 3-pt and the header stage for the remote. I also mounted the combine reservior.
mj
08-20-2002 08:35:19
Use an open center valve with power beyond. The open center port returns to the reservoir and the power beyond goes to the depth control unit on the Eagle hitch. The pump connects to the in port. Ports A & B go to the cylinder, motor, etc.
