Pto on dc case
shayne munter
08-16-2002 17:42:20
i was wondering if anyone could tell me if you can set the pto clutch on a 1952 dc case.
Bruce Nelson
08-17-2002 06:06:23
 Re: pto on dc case in reply to shayne munter, 08-16-2002 17:42:20
Shayne, sure you can. Remove the top cover over thr PTO clutch. Rotate the clutch till you see the lock pin that holds the adjusting ring from turning. Pull the lock pin back & rotate the ring clockwise a notch or two. Repeat if necessary. It's much like adjusting the engine clutch.
Bruce
