Power steering pumps
Gene
08-15-2002 10:23:43
I have a model 831 case-david brown tractor I am trying to refurbish. The power steering pump is leaking badly where the steering wheel shaft enters the pump housing. Can this seal be replaced without totally removeing the pump from the tractor. If it can, how do you go about doing it?
AL 2
08-15-2002 13:59:48
 Re: power steering pumps in reply to Gene, 08-15-2002 10:23:43
Sounds like you have the same problem as I have. Did you see my post a few days ago (8-13-02) re 530 CK. Al.
Gene
08-15-2002 16:16:44
 Re: Re: power steering pumps in reply to AL 2, 08-15-2002 13:59:48
Al,
No I did not see your post of 8/13/02. I have everything off the tractor down to the power steering pump. Just a little afraid of tearing into it without knowing what I'm doing. Any words of wisdom?
Gene
AL 2
08-15-2002 18:29:17
 Re: Re: Re: power steering pumps in reply to Gene, 08-15-2002 16:16:44
Gene. I can't help much as this problem is new to me and also I don't know if your steering system is like mine or different. In my case, the seal and pump are only a few inches below the steering wheel. Try a search on this board or look at the forum archives. Good luck. Al.
