Re: Are the Rear PTO's for VAC's interchangeable acr
VACLee
02-10-2021 05:25:58
There are two different PTO assemblies for the VA series. One was used up through 1948. Starting in 1949 they changed the design due to interference with the engaging lever and the mounting point for the top link of the 3 pt that was introduced that year. The early style has a longer lever the moves left to right to engage the PTO. The later style has a short lever and a vertical rod that you pull up to engage it. Either one will bolt up but the later style is a little more user friendly even if you don't have 3 pt. There actually is a third style that was used on the VAS and VAH but they will not fit any other models. If you are going to try to mount a factory 3 pt you will have to change the rear end housing as yours will not have the 4 mounting bosses that the rockshaft bolts to. There were some conversion kits at the time, but none of them will be as convenient to use as the factory setup. Where are you located? Lee
Hot Rod
02-11-2021 07:21:11
 Re: Are the Rear PTO's for VAC's interchangeable acr in reply to VACLee, 02-10-2021 05:25:58
Good morning and thanks for the info. Sounds like I will be ok in putting a PTO from a 1946 VAC on my 1948 VAC. Your info on the 3 point hitch options is also very much appreciated. From the looking I've done i knew there were options but haven't spent a lot of time digging into that yet. We are located about 1.5 hours north of Seattle in the great state of Washington. If you've got any thoughts or ideas on someone in this area that might have parts or spares I'd sure appreciate the guidance. Thanks again and have a great day!
Bob Bancroft
02-11-2021 07:53:50
 Re: Are the Rear PTO's for VAC's interchangeable acr in reply to Hot Rod, 02-11-2021 07:21:11
I probably have almost everything you need, in NY state! Blast! Why does it always turn out like this? I've got a late VAC parts tractor with complete Eagle hitch, I think, except for a hydraulic line.
