Stalling and losing Power
Tim D
08-14-2002 05:23:29
I have a 540 gas that I have owned for about a year. Recently after running the tractor hard for about an hour it started to stall out under very light load. If I shut it down for a little while it starts right up and has plenty of power. I notice last night frost had developed just above the carb. Any ideas? Thanks
Allan
08-14-2002 21:34:53
 Re: Stalling and losing Power in reply to Tim D, 08-14-2002 05:23:29
Ideas...yes. You are getting carb Ice. this can happen if the humidity is high and the temperature less than 60 degrees or so. There really isn't any cure on a tractor with a cold manifold.
Tim
08-27-2002 17:48:35
 Re: Re: Stalling and losing Power in reply to Allan, 08-14-2002 21:34:53
I have a 53 VAC having similar problems. No power, cold intake (no frost though). It has a plethora of other problems (i.e. needs rebuild bad). Never heard of this type of problem.
