Case SC won't run only backfires!
Shaips
03-12-2006 11:40:33
I have a 1948 Case Sc that was running great, then next time I had it running it seemed to run rough then it would clear out and run OK. It got worse quickly and now it will only backfire when I try to start it. It has fire to the plugs, which are new, and I have had the carb off and it looks fine inside. Any suggestions? Thanks for your help
Shaips
04-12-2006 06:21:17
 Re: Case SC won't run only backfires! in reply to Shaips, 03-12-2006 11:40:33
Well I have not had time to do anything with this tractor yet, But I am going to this weekend. How can I tell if the magneto is working correctly? I know it could use a new cap, anything else I should get for it? Where can I find a new cap. thanks
ben830
03-13-2006 09:25:06
Check your Rocker arm shats are tight and didnt come loose. I had this happen to our case LA. It slowly started backfireing and got to the point it wouldnt even start.
Shaips
03-12-2006 19:11:58
My wires are not crossed. I tend to think it must be the magneto like Gene said. I will have to take it apart and look at it. Thanks
Gene Dotson
03-12-2006 18:20:26
My DC acted the same way. The problem was a broken spring in the impulse coupling on the magneto allowing the timing to retard. John Saeli was able to supply me with a good spring and now the tractor runs fine, Thanks John... Gene
Shaips
03-12-2006 17:11:51
Well I am getting plenty of gas, the gas is new. All 4 plugs were cleaned and tested to see if they had spark while cranking the tractor and they did. Whats next? Thanks
dctom
03-12-2006 17:24:26
 Re: Case SC won't run only backfires! in reply to Shaips, 03-12-2006 17:11:51
you sure somseone didnt cross the plug wires?? sounds like a timeing problem
mike's600
03-12-2006 18:15:32
 Re: Case SC won't run only backfires! in reply to dctom, 03-12-2006 17:24:26
DcTom has it right,somehow you got your plug wires out of sequence.I did the same thing.I was one off the firing order. It would backfire.
todd hamilton
03-12-2006 16:28:28
Check the sediment bowl and fuel line - starving for gas will cause an SC to act like this.
Casenut
03-12-2006 14:58:38
Sounds to me like you have moisture in the distributor or and bad distributor cap?
stout1
03-12-2006 14:36:03
Since I'm not sure how often you use it (no time frame given) I am guessing that you might have bad fuel. New fuels only last about 2-3 months before they "expire" and should be changed. Try new fuel and if that's not it let us know and we'll try to come up with something else.
Michael
