What is the best way to remove a roll pin without much hard hammering?
R Wyler
08-12-2002 11:33:52
I just went and ordered my gearshift indicator parts for my 930 I will have to remove two roll pins one on the gearshift lever and one on the inicator on the shaft that goes into the top of the transmission. I want to be as gentle as possible to avoid cracking anything. Anyone have any suggestions? Thanks. R Wyler.
Dale(MS)
08-12-2002 17:16:31
 Re: What is the best way to remove a roll pin without much hard hammering? in reply to R Wyler, 08-12-2002 11:33:52
I'm with Robert! Use the correct size roll pen punch.
R Wyler
08-12-2002 19:02:35
 Re: Re: What is the best way to remove a roll pin without much hard hammering? in reply to Dale(MS), 08-12-2002 17:16:31
You are right I will just have to use a hammer and punch and carefully drive it out. Thanks for the help.
Woodbeef
08-12-2002 16:35:34
If it is a tapered roll pin make sure it comes out from the right direction.
R Wyler
08-12-2002 19:04:01
 Re: Re: What is the best way to remove a roll pin without much hard hammering? in reply to Woodbeef, 08-12-2002 16:35:34
Yes I will make sure of that. thanks for the help.
robert
08-12-2002 14:19:57
Get a roll pin punch set. Use the proper punch.
R Wyler
08-12-2002 19:05:52
 Re: Re: What is the best way to remove a roll pin without much hard hammering? in reply to robert, 08-12-2002 14:19:57
I did not know that they made roll pin punches that would be a very nice thing to have. Thanks for the help.
