Motor I.D. help
Dean
08-12-2002 07:28:45
Hi I have a 64 case model 530 4 cyl gas engine, its time to replace, or rebuild, what would my options be, and who is the manufacturer of this engine, sorry to be vague, I dont have the cubes, but I want to say 161, or 191. I s that a ford, or was this a case industrial. Is there a kit so I can swap it out with a later model 4 banger?? Thanks in Advance, Dean
Jim M
08-12-2002 15:28:49
 Re: Motor I.D. help in reply to Dean, 08-12-2002 07:28:45
You might also go to a 188 gas out of a 630 or a 207 out of a combine.
jeff
08-12-2002 12:20:25
THE MOTOR IS MOST LIKELY A 159 GAS MANUFACTURED BY CASE THAT WAS THE MOST POPULAR GAS ENGINE THERE WAS ALSO A 148 THAT WILL FIT BUT I BELIEVE YOUR BEST BET IS TOO EITHER REBUILD THE 159 OR IF YOU WOULD LIKE TO GO DIESEL THE 188D WILL BOLT UP BUT IS 1 1/4 INCHES LONGER IN THE BLOCK
