Non Detergent motor oil for my Case, 1935 wheel tractor
Gary Lange
08-11-2002 17:31:16
I have a 1935 Case wheel tractor with a kerosene/gas engine. I run it on gas. It has four cylindres, very long stroke with oversize sparkplugs. It runs good once started. I can no longer find non-detergent motor oil for the crankcase. I was told by the former owner when I purchased it in 1974 that I must not use detergent oil as it would ruin the bearings and seals. I have always followed his direction and the tractor runs fine. Do any of you know where I can find 40 weight non-detergent motor oil? Or have other suggestions. The auto parts place said I could use compressor oil, as it was non-detergent. It is only 30 wt but I can add an oil additive to thicken it up. I hate to see the engine ruined after all of these years.
joecool
08-12-2002 04:03:27
 Re: Non Detergent motor oil for my Case, 1935 wheel tractor in reply to Gary Lange, 08-11-2002 17:31:16
We use non detergent 30weight oil, we use shell make, it is bought at local Advanced auto parts store. Also Citgo makes a 40weight non-detergent oil. Check more than one local store, also check wal-mart. I saw some non-detergent there yesterday.
Mike Patrick
08-13-2002 13:38:40
 Re: Re: Non Detergent motor oil for my Case, 1935 wheel tractor in reply to joecool, 08-12-2002 04:03:27
I have a Case D, and a John Deere D. I use 30 wt. non-detergent oil in both of them. I find my 30 wt. non-detergent oil at Wal Mart. It is less than a dollar a qt.; something like 80 cents a qt. I haven't had any trouble out of either of my tractors, and I use them to plow with in the spring.
Wolverine
08-11-2002 19:41:44
Gary, I would stick with the non detergent. But do not use a compressor oil they contain some anti foaming agents and not enough rust inhibitors. I use CenPeCo oil out of cleveland 1 800 553-1891 ask for blaine. They make a special oil for Antique Tractors that is heavy in Anti rust and Storage protection without being a Detergent oil. Check them out at "Cen-Pe-Co.com" they will ship anywhere. I use their non detergent 20 and 40 weight.
Tom
08-12-2002 11:16:25
 Re: Re: Non Detergent motor oil for my Case, 1935 wheel tractor in reply to Wolverine, 08-11-2002 19:41:44
NAPA auto parts as well as Autozone can supply you non detergent oil also.
