SC seat and brake parts....Thanks jal SD
Wayne in Mo
08-10-2002 20:48:19
I took another look at my seat and now I wonder if there ever was any large coil spring there. Is the rubber biscuit the only thing that supports the seat and not a coil spring and shock absorber? I had assumed there was a coil spring missing! Also the stamped steel drum that fits inside the belt pulley was completely worn in half by the brake shoe that stops the movement to facilitate shifting. I think I can find a 5 in steel sleeve that can be welded onto it for a repair. It is a simple part but likely not available. Thanks jal SD for the info. I did not realize that few of these were made with the foot clutch. I am not anxious to pay $120 for the rubber biscuit but may have to. Can you get me the address/phone of the outfit that handles them?
Wayne mo
08-12-2002 21:47:25
 Re: SC seat and brake parts....Thanks jal SD in reply to Wayne in Mo, 08-10-2002 20:48:19
Thanks for the info on the lack of shock and spring from Richard. I kept looking for one of each on Case SC and never did see any. My 53 has the double rubber biscuits with a bracket sandwiched between and the rubber is shot. I did not realize the rubber would handle all the seat movement and I guess it did barely! I like the SC also but am surprised the pto is located so high up causing the shaft to be at a great angle on my pull type brush hog.
Minn-Kota 320-839-3940 or 320-289-2473. Thanks.
08-11-2002 18:56:25
Thanks.
Richard
08-11-2002 18:11:11
Sorry I forgot this , I hope its still good www.minnkotarepair.com
Richard
08-11-2002 17:53:01
There are lots of part you can get but you have to have part #s . The seat has no shock or spring, just one rubber torsion spring .Later tractors had two (400) but they are not the same. The 53 is also the first year for aluminum piston 3-5/8 from gray iron 3-1/2 a littil more horses !!! I love my 53SC
