Still Carb problems
Bill
08-09-2002 13:04:17
Thanks for the info, but I'm still having problems. After I run my 530 for awhile(2-3hrs)it shuts off. I think it might be due to the heat. Vapor lock or something??? It's a backhoe, I didn't mention that before, so I'm not traveling at all to help with the cooling.Thanks
gm
08-11-2002 19:58:17
 Re: Still Carb problems in reply to Bill, 08-09-2002 13:04:17
You could feel the fuel lines and see if
they are hot. Make sure they dont touch
or run too close to the exhaust.
The fuel has to be quite hot to cause vapor lock. Seems like it
would happen within in hour of running.
Try running with the fuel cap loose, maybe
that is not letting air in the tank.
-Greg
Larry
08-10-2002 08:38:49
Tractors are designed to sit an run in one place. Otherwise you wouldn't be able to grind feed,ect. Maybe you are having trouble with the ignition part of it. Did you ever check to see if you still had spark after it shut off? Could be a bad coil or condenser.
