Ray- I should be able to answer most of your oil change questions on the SC tractor: Type of oil?- I use S.A.E. straight 30 weight non-detergent oil. If the engine has been rebuilt and there's no sludge buildup... then I'd go ahead and switch over to regular 10W-30 oil. How often should it be changed?- This probably depends on how much you use the tractor. I do it every 6 months, but I only mow my place once a month. Where can I find a filter?- I don't know if you are asking what is the part number of the filter, or where is it located... so I'll answer both. The filter is in a round canister on the right side of the tractor above the starter. The top removes with a 1" wrench- and the filter is a cannister type. The type of filter that will work is either a NAPA Gold #1271 or a Fram #1080. Where do I pour the oil in?- There is a filler cap between the magneto and the governor housing on the right side of the engine- up front near the radiator. I believe it takes about 5 quarts. People on the board have mentioned pulling the drain plug for the wet clutch to remove that oil as well... but I haven't ever done that. How do I check the oil levels?- As you noted, there are two plugs on the side of the oil pan. The oil level shouldn't be below the level of the bottom plug. You pull the top plug to check the level. I've actualy got a spring plug on my pan here. I pull the top ring, and if oil drips out... I know the level is fine. Hope this helps you. Happy Tractoring! -Schotte
