Electrolysis help, please
Mike Schotte
08-07-2002 05:22:24
Hi All-
Well, I mixed up my first vat of electrolyte solution last night, but I have yet to get started de-rusting parts.
I can't seem to find my old battery charger- so I hooked the vat up to my new top-of-the-line Die Hard battery charger and got... nothing (except a "Check Battery" light.)
Baggsy told me that he had heard you could get around the problem with the new chargers if you hooked up a car battery to the circuit as well. This leads me to my two questions:
1) Should the battery be hooked up in series with the charging circuit, or should the battery be hooked up in parallel with the part to be cleaned?
2) Will a crappy old battery work for this application, or do I need to find an actual working battery?
Thanks in advance for you help.
-Schotte (still rusty)
Zach
08-09-2002 14:10:16
 Re: Electrolysis help, please in reply to Mike Schotte, 08-07-2002 05:22:24
where do you get the washing soda?? is there another name for it? does the baking soda work just as good. i went to wal mart and couldn't find washing soda.thanks Zach
Baggsy-Wy
08-09-2002 17:13:17
 Re: Re: Electrolysis help, please in reply to Zach, 08-09-2002 14:10:16
Arm & Hammer Washing Soda, at the grocery store with the laundry detergents. I got mine at a Safeway while Albertsons didn't have it. E-mail me and I can get you the UPC code if you need...
Zach
08-11-2002 07:50:26
 Re: Re: Re: Electrolysis help, please in reply to Baggsy-Wy, 08-09-2002 17:13:17
thanks i will check it out then i will get back with you on the upc code. thanks
RK
08-07-2002 17:35:31
Mike, are you sure you have good connections between charger clips and piece to be cleaned and the piece to be sacraficed? Justed started cleaning things up this way myself last week, but learned quick that you need good connections. Use a small file or bit of sand paper to remove a bit of the crusted rust where clip will attach. If charger is plugged in when you attach second clip, you should hear the spark arc. If you're like me you won't believe the job this process will do on rust, it is like some kinda majic..Good luck.....Bob
Mike Schotte
08-07-2002 18:08:45
 Re: Re: Electrolysis help, please in reply to RK, 08-07-2002 17:35:31
Hi Bob,
Looks like it's working, now. Thanks for the advice. One of these things did the trick:
1) brushed a clean spot on the rusted piece
2) Hooked the charger up before I hooked up the anode
3) Changed the charger from "Automatic" to "Manual"
After everything was going, I was able to take the car battery out of the loop and everything kept on truckin'
I've got bubbles coming off of both the anode and the rusted piece, now. Nothing big- nothing crusty or foamy like I expected... but something's definitely happening!
I'll let it run for a few hours tonight and see what it looks like tomorrow.
Thanks to everyone.
-Schotte
RK
08-08-2002 14:44:58
 Re: Re: Re: Electrolysis help, please in reply to Mike Schotte, 08-07-2002 18:08:45
Mike, bubbles are all I get during this process but seems to work fine. The web site I got the info from said to remove part after about 1 hour and give it a good brushing, then cook it somemore. After a couple of hours, I use an electric drill and wire wheel to remove the oxide that forms on small parts, or just a wire brush on larger pieces.(they will shine like a new nickel, literally) Bob
Mike Schotte
08-08-2002 16:33:19
 Re: Re: Re: Re: Electrolysis help, please in reply to RK, 08-08-2002 14:44:58
Hello again Bob,
I've got an exhaust manifold cookin' right now. I only am getting bubbles in area about 3 square inches nearest the anode. Over the weekend I'm going to try and hook up a larger anode grid that surrounds the tank... as I would have to move the anode around forever to get all the areas of the piece I'm currently doing.
I let the test piece from last night (and oilfield drill bit) cook for about 8 hours. It didn't do everything, but it did something. I washed it with a plastic brush and got some oxide off... but I haven't hit it with a wire wheel yet.
It doesn't look spectacular- so maybe I need to clean between cook cycles like you suggested. I used this piece as a test because I wanted to see if electrolysis would free up moveable pieces that have rusted together. No progress yet, but I'll keep you posted.
Thanks, -Schotte
Baggsy-Wy
08-07-2002 09:59:45
Here's a link to the problem and solution...
Nothing yet...
08-07-2002 17:00:20
 Re: Re: Electrolysis help, please in reply to Baggsy-Wy, 08-07-2002 09:59:45
Just got finished trying the tricks from the web site.
Hooked the car battery up in parallel with the charger & the vat... nothing.
Hooked the car battery up in series with the vat... nothing.
Took a 12V back up light that I used on my tractor and hooked it in parallel between the charger and the vat... nothing. (not even a light)
Changed my anode to a solid piece of stainless steel and moved the anode closer to the part... nothing.
It looks like the old car battery I have is totally toast. I may have to pull a good battery out of my Falcon to see if that solves the problem.
Other than that- I'm out of ideas. The part I've hooked the negative cable is rusty, but not excessively so. Do you have to grind down to bare metal to make the connection? If so, that would defeat the whole "non-destructive" philosophy of electrolysis.
I'll keep ya' posted.
-Schotte
Mike Schotte
08-07-2002 10:57:27
Hi Jeff,
Thanks for the info. To hook up the battery to the circuit as well, I'm going to have to get my jumper cables involved-
The contact tips on the jumper cables are copper instead of steel (unlike those on my battery charger.)
Is copper going to cause me any problems in the vat? (I know- only the negative side comes in contact with the solution.)
Just as an aside- I wonder if the charge of the battery would cause the charger to taper off the power to the electrolyte solution and mess you up, as well.
Regards, -Schotte
