DC Case,need info!
JH WEAVER
08-06-2002 13:29:13
Can anyone tell me if sleeves are available for this tractor. This is a 1948 DC and has severe engine problems. When rod bolt came loose,she made junk out of sleeve,rod,piston,and scored the crank. If anyone has any info on these ,please respond,if it is going to cost me the farm to rebuild,this tractor will be for sale.Thank you.
RobertTX
08-07-2002 06:07:57
 Re: DC Case,need info! in reply to JH WEAVER, 08-06-2002 13:29:13
Used parts are very available and reasonable. New parts are also available (some from CaseIH), but can be a little expensive. Unless you have a strong desire to have a fresh rebuilt engine, good used ones should do fine. Your biggest problem may be replacing the crankshaft. I haven't done one, but it is a challenge.
