SC seat and clutch brake
Wayne in Mo
08-06-2002 07:22:34
My SC is a late model (53 I think) with a foot clutch. The clutch brake drum and shoes are completely worn out. They stop the main shaft from turning when you depress the clutch and allow you to shift without grinding the gears. I have to wait till the transmission winds down in order to shift gears now! I also am missing the seat spring, shock absorber, and bracket. Is this model rare and difficult to find parts like these. Are there any junkyards near St. Louis that would have these items. Most CAse SC tractors i have seen have the hand clutch and different seat designs. I really like this tractor, it has a mag and you can't crank it slow enough not to start on the first turnover! It is a good puller too!
C. Amick
08-07-2002 09:59:01
 Re: SC seat and clutch brake in reply to Wayne in Mo, 08-06-2002 07:22:34
I am not familiar with the SC's with foot clutches, but I took the hand clutch brake shoe to a local shop that relines clutches and brakes. He riveted a new piece of lining on it and it has worked fine.
jal-SD
08-07-2002 07:14:35
SC's with foot clutches, Eagle Hitches, LPTO & live hyd. are fairly rare. According to information that I've read, there were about 1,135 of them made. I've got one that we re-built the engine in last winter. Have you tried your local C-IH dealer or Don L @ Austin, Mn on the clutch-brake parts? (My C-IH dealer was able to get the return springs for my clutch and brakes @ $10 ea.) Min-Kota repair has the rubber bushing seat parts, but they are not cheap-had to give 'em $125 for mine-my C-IH dealer didn't have a clue on seat parts. I have the large single rubber on mine-they say there were two types used & the other one is a little less expensive. I'll have to look up the address for Min-Kota, so if you want it, post back. (My $0.02 worth. jal-SD)
