David brown 885 diesel engine studder
Robert
08-05-2002 20:11:25
Just wondering if anyone could point me in the right direction on this thing.Engine starts and runs the best to about 3/4 throttle then starts to blow black smoke and starts to miss or studder,first dealings with a diesel any info would be great.
Elmer
08-06-2002 09:25:47
 Re: david brown 885 diesel engine studder in reply to Robert , 08-05-2002 20:11:25
There is a cold start valve on the rear side of the injection pump. Make sure it is not turned in. Clockwise forin and counterclockwise for out.
Robert
08-06-2002 19:07:56
 Re: Re: david brown 885 diesel engine studder in reply to Elmer, 08-06-2002 09:25:47
Went out and checked the valve it is all the way out,also noticed today smoke is not as black but maybe grey?starts way to good for me to beleive motor.very little blowby,no smoke untill 3/4 throttle or above, any more ideas? Thanks Robert
Elmer
08-07-2002 04:09:48
 Re: Re: Re: david brown 885 diesel engine studder in reply to Robert , 08-06-2002 19:07:56
Maybe the metering valve in the injection pump is stuck. You must have a pump problem.
Jeremy
08-08-2002 00:21:20
 Re: Re: Re: Re: david brown 885 diesel engine studder in reply to Elmer, 08-07-2002 04:09:48
Sounds to me like the quill shaft that drives the pump is worn, this retards the injection timing and gives the same effect as the cold start being screwed in ( hence the good starting that you notice). Suggest you slacken the three nuts that hold the pump body to the engine and rotate the pump to advance the timing. I have done this before with the engine running and you can hear the exhaust note change and clean up. If the shaft is really worn it will have to be replaced.
