Dc
tim
08-05-2002 11:01:11
I have a 1950 dc - I am not getting enough oil to the rocker arm shaft it only drips about a drop every 5 min. I took the shaft off and found the tube that carries the oil has a steel plug in it with only a small gap around the outside - how much oil is too much - we have a 41 dc for parts and it dosent have the plug - how do you take the tube out - is this a major problem - I was told on the cc case you took the valve cover off every 100 hours and oiled it by hand - any help would be appreciated - thanks in advance
Old Iron
08-05-2002 18:37:26
 Re: dc in reply to tim, 08-05-2002 11:01:11
Check the holes in the rocker arm shaft to make sure they are clear. The holes should point down on a 45 degree angle towards the push rods. You should have about one drop every 5 seconds from each rocker arm.
Bill Hires
08-05-2002 15:16:11
When reassembling rocker arms and shafts on D series, insatall the shaft with the lubricating holes facing downward. This is the only refrence I can locate on D series rocker arm lubrication.
Bushings and/or shafts should be renewed if the diametral clearance exceeds a suggested value of .008. Rocker arm bushings which are provided for service, require final sizing after installation to a bushing inside diameter of .6265-.6275, so as to provide a diametral clearance of .002-.003. JI Case I&T Manual C-201
