Case VA electrical system
Tractor Boy
08-04-2002 17:34:27
I was wondering if anyone knows about a website with a electrical diagram for a 1949 CASE VA. I also read somewhere about giving your serial number to case to find date of manufacture and who originaly bought it and was wondering if there is a website to do this on. Any help will be greatly appreciated. Thank You Tractor Boy
mj
08-10-2002 00:09:05
 Re: Case VA electrical system in reply to Tractor Boy, 08-04-2002 17:34:27
Try this link to find out more about serial numbers than you will want to know!
mj
08-10-2002 00:14:02
 Re: Re: Case VA electrical system in reply to mj, 08-10-2002 00:09:05
I see that the link didn't take so here it is again:
John H
08-04-2002 18:08:24
Don't know if there is a web site for the electrical diagram but some one shold be able to email you one. I've seen previous posts where someone had one. Go to page two and get the email address for SmartAxe (Got the 40 DC-4 post) as you have to call Case to get the info using your serial number.
Thanks.
glen bost
08-07-2002 11:54:56
 Re: Re: Case VA electrical system in reply to John H, 08-04-2002 18:08:24
I need 6 volt wireing diagram
mj
08-10-2002 00:04:02
 Re: Re: Re: Case VA electrical system in reply to glen bost, 08-07-2002 11:54:56
The wire from the generator cutout or regulator (earlier were cutout, later were regulator) runs to the ammeters' left post (viewed from dash side). From that post a wire goes to light switch (post on end of switch); the other post connects to the lights. There is another wire from the same ammeter post that goes to the ignition switch, and a wire from the other ignition switch post goes to the coil. The right post of the ammeter has a wire that goes to the battery side of the starter switch. The headlight switch has three positions: 1st - All the way in: provides 3 amps. to the circuit; 2nd - halfway out: provides full (12 amps.) to the circuit with lights off and 3rd - all the way out: provides full generator output (12 amps.) and allows lights on.This switch also contains a 15amp. fuse. The Case manuals label them as follows: 1st position - lights off, 2nd position - lights off for day-time battery charging only and 3rd position - lights on. If you had a regulator instead of a cutout then the light switch would be a simple fused on/off switch. The charging rate of the cutout type generator is adjustable by removing the brush access cover band and moving the third brush; the regulator type generator is not adjustable. The listed bulbs for headlights is #1133L(32 Candle Power) and #51(1 C.P.) for the small rear light (large rear uses the same as headlights).
Tractor Boy
08-10-2002 20:52:57
 Re: Re: Re: Re: Case VA electrical system in reply to mj, 08-10-2002 00:04:02
THANK YOU TO ALL THE PEOPLE THAT REPLIED TO MY QUESTIONS. TRACTOR BOY
