Electrical trouble shooting help needed
James
08-01-2002 16:21:00
My ignition switch and light switch test ok as long as nothing is connected (12 volts). However, when the wires to the starter or the headlights are connected, I can't get a reading over 1 volt. I'm refering to the output side (the input side always has 12 volts). For example, if I turn the key to 'start', I get a good reading until I hook up the wire to the starter.
What is the possible problem?
Steve
08-04-2002 14:01:48
 Re: Electrical trouble shooting help needed in reply to James, 08-01-2002 16:21:00
When the switch is on, the contacts are supposed to be "shorted". When the switch is on, the contacts are together and so your reading the same point with both of the meter leads. Try disconnecting the wires from the switch all together, input and output, and check the resistence across the output terminals both with the switch off and on. With the switch off, there should be nearly infinite or at least very high resistance, say in the Megohm range. With the switch on there should be little or no resistance, like less than 10 ohms. Also, test the resistance from all of the terminals individually to the case of the switch (with all the wires disconnected) there shoul be very high or infinite resistance on all of them. If your switch is off and the wires are hooked up, and you can't get 12 volts across the output then the hot wire is shorted to ground somewhere, probably before the input side of the switch, Possibly even inside the switch itself. Hope this helps.
Pat T
08-02-2002 03:35:58
James-
Sounds like your ignition switch is bad (hi resistance contacts inside). You can verify this by taking the wire to the lights and touching it directly to the +12v wire going to the keyswitch. If light circuit is ok lights should work. Same with starter wire. Just be careful, if there is a short in the wiring somewhere else, those wires will get hot right NOW!
Pat
