random thought
jallread
03-11-2006 18:39:40
Can you adjust the pressure that the hydraulic pump puts out on a late 60's Case 440?
Tom (Ks)
03-12-2006 06:58:30
 Re: random thought in reply to jallread, 03-11-2006 18:39:40
You should run the loader through your remote valves. If you are lucky, you have two of them. Don't worry about any extra pressure, there is not any. Some did not have remotes or only one, then you have to add one or two. They may hard to come up with. GOOD LUCK.
Tom (Ks)
03-11-2006 19:52:16
Yes, but it's good sized job. The relief valve is built into the oil pump. You remove the valve housing on top of the torque tube to get to it. Spec is 1450 to 1550 PSI.
jallread
03-12-2006 05:47:19
 Re: random thought in reply to Tom (Ks), 03-11-2006 19:52:16
Thanks Tom (ks), A follow up question if you don"t mind. If a front end loader was added to the tractor would you have to adjust the pressure in the system? And in turn if you then took the loader off would there be too much pressure for the 3pt control cylinder to handle?
Thanks for the knowledge.
