Vac plow
Don
07-29-2002 18:56:39
I have a 1950 case vac with the eagle hitch & have been looking for a two bottem 3pt plow for it for some time.I located one & it came off a 1946 vac.It is a 3pt hookup and I wondered if it would fit my vac.Plow is in good shape & it`s all there.Is it worth fifty bucks? Thanks, Don.
Lucas
07-30-2002 08:43:15
 Re: Vac plow in reply to Don, 07-29-2002 18:56:39
A 1946 VAC wouldn't have had an Eagle Hitch.
mj
07-30-2002 14:39:14
 Re: Re: Vac plow in reply to Lucas, 07-30-2002 08:43:15
Could have the add-on 3-point for the high-pressure system that was offered from the factory thru the dealers. With either one the best thing to do is to make up a new set of draft arms with the swivel-ball ends so you can hook-up ANY 3-point equipment. Keep the Case arms for jobs that need rigid lateral control if you want but I just use my ballend draft arms with sway chains most of the time.
