Case Vac parts
Frank in Ohio
07-28-2002 20:46:12
I am the proud owner of a 50's vintage Case VAC that like most needs a little TLC. First I need to replace the Intake/exhaust manifold. The one that I have was broken and was brazed but the weld job looks like some one spit weld on it. It also leaks! Does anone sell new replacement manifolds? Secondly, the air cleaner is missing its cap and bottom bolt on dust collector. Do air cleaner assemblies from other case models fit a VAC? Is there a good case parts yard in the PA/Ohio/WVA area? Thanks for your help!
Lucas
07-29-2002 05:10:04
 Re: Case Vac parts in reply to Frank in Ohio, 07-28-2002 20:46:12
Ed Axthelm should be able to help you with a manifold. Give him a call. 419-864-4959
CASEPOWER
07-29-2002 04:31:00
Hey, all the air cleaners on the VA series are the same. The caps are getting kind of hard to find. I have good used manifolds. CASEPOWER
