Cracked Housing
Larry K. Noller
07-28-2002 19:28:04
I recently found the hydraulic leak on my VAC. I found that the bottom of the round section of my
rock shaft housing has a section broken out of it. The book says that any fluid that is getting by the piston collects in the bottom (where it is broken out) and is bled off by the relief line. It looks like someone tried to lift something too high causing the big cam to come around and hit the housing too hard or ????? ????? ??. I would like some advice on what caused this. Do I have a bad lift valve or did the previous owner do something wrong (I just bought this thing). I don't want to get another one and have the same thing happen. Thanks in advance.
Larry
CASEPOWER
07-28-2002 19:40:43
 Re: Cracked Housing in reply to Larry K. Noller, 07-28-2002 19:28:04
I have seen this before. The one I had seen the operator was pushing with a scrape blade turned backwards and I guess he thought it was a dozer it forced the Rocker arm that the connecting rod for the piston rides on to bust through the housing. I doubt you have a hydraulic problem. I do have a rockshaft housing off and ready to ship if you are interested. CASEPOWER
Larry
07-28-2002 20:02:53
 Re: Re: Cracked Housing in reply to CASEPOWER, 07-28-2002 19:40:43
Thank you very much. I can see that pushing against the housing like that would break it. I had thought about putting one of those rear mounted buckets on it, but now I guess I had better rethink the idea. Thank you again.
Larry
