Larry; Yup... 1949 DC-4. I'm sure we've conversed before. I've now ruled out the connecting rods. All are shimmed to within specs(using plastigage). First time I did it the valves sounded fine. I then realized that I forgot to check the bore so, in I went again. Next step is to remove #3 rod, piston, & pin to look for wear in the top end. Go slow is usually my philosophy, especially in new territory...Anyways to the valves... Needed workshop for another task so I put it all back together & started her up. was initially hard to start...no gas...duhhhh. Then started right up. Still a knock but the valves are quite a bit noiser than before, like a diesel clatter. My wife who is not overly experienced with engines identified a difference as I drove past on the way to the shed. Oil pressure gauge came up to full pressure immediately(30 - 35 pounds) Two more things....After all of the fiddling with the connecting rod, I poured gas into the oil pan to let it sluice away any last traces of dirt and little black gasket goo pieces. Oil strainer had been cleaned earlier and was in place when the gass was added. Gas was in for about 10 minutes, then it was drained and left with plug out to dry. After visual inspection, the next day, regasketed observation plates, 24 hours later, 10w-30 oil was added. In total she has run about 10 - 15 minutes since put back together. As in above post, she was sitting through that hot weather for 4 - 6 weeks with no oil. The only other thing I can think of is that the second time I was working on her, I was hand cranking her to get the piston into position without removing the spark plugs. After one revolution(lots of grunting, I realized that she was in gear with the clutched engaged. Lastly, tried 1/4 cup of diesel fuel to 1/4 tank of gas( 18 litres or 4 gallons). Gramp used add a quart of diesel to every tank each fill to " keep the valve train clean". Didn't appear to sound any different. You now know what I know...I hope it helps. Thanks in advance for your response. Greg
