L Case tires
cil
03-11-2006 11:52:07
I need a set 15x30 tires for my L. Anybody know where to look?
Walt Davies
03-13-2006 12:22:46
 Re: L Case tires in reply to cil, 03-11-2006 11:52:07
Do you want 15X30 or 14X30 tires
What you have been quoted are for 14X30 tires
15X30 are now 18.4X30
14X30 are 16.9X30
There is a lot of differance in the two tires I have both on my Case LAs The 15X30 (18.4X30) tires are a lot bigger than the 14s and may not fit the L. Walt
Fordfarmer
03-12-2006 10:24:40
Any ag tire dealer should be able to get you a set a tires to fit 15x30 rims. 16.9x30 or 14.9x30 would both work, but I'd lean toward the 16.9's as they are designed for a 15" rim. They are still used on plenty of tractors, for both the front axle on F.W.A. tractors, and rear tires on 40-60 h.p. I have a set of used 16.9x30 Goodyear Power-Torques in my shed that I've been keeping in case I need them for my duals.... If I'm close enough to you to make it worth the trip, I'd be willing to sell them.
L.C.Grey
03-12-2006 10:02:44
14.9/16.9 x 30 tires aren't too hard to find again. They were considered an oddball size for years but have made a comeback as front tires on large forward assist tractors. The only problem is is most now are radials and if they are in pretty good condition they want as much for them as brand new bias plys. I too have beeen watching for 4 and so far only found one good one at a bargain price.
Mathias NY
03-11-2006 18:55:59
I think your modern tire size is 16.9x30. Try looking at www.kenjones.com for tires. It looks like he has mostly imports, but he seems to have sizes that www.millertire.com does not. His prices are a little better too. Ken Jones is located in Massachusets. Miller Tire is in Ohio. Good luck.
