DB hydrostatic steering
James
07-24-2002 20:36:17
Is it normal for the David Brown hydrostatic steering to whine a little when in motion? (Early '70's)
Elmer
07-25-2002 03:15:31
 Re: DB hydrostatic steering in reply to James, 07-24-2002 20:36:17
David Brown tractors used two different sets of tming gears, early ones had coarser teeth than the later. If you have the early set and they are noisey hen turning the steering, that is a sign that they are wore. Change them before a tooth breaks off. I have seen situations where the broken tooth has meshed into two gears and eith broke the end of the camshaft off or broke the end of the crank shaft. The sound is more like a deep growl though.
