Quietubg Valve Nosie
Greg
07-23-2002 17:38:44
Greetings
My Case DC-4 has been sitting for a while( 4 to 6 weeks) in a very warm shed without oil in it while I've been working on adjusting rod bearings. I have been moving crankshaft by using the hand crank( hard work when the plugs are in) Got the rods readjusted and torqued, closed it all up and started it up....
Knock is still in the engine( so next is the removal of the offending piston to check the pin); however, I noticed that the valves are suddenly quite noisy( like a diesel clatter). Oil pressure is good( 30 - 35 pounds). I am using unleaded gasoline with a fuel stabilizer... and 10w-30 oil
Any ideas? Suggestions to quiet them?
Thanks a bunch in advance for your thoughts!
Greg
C. Amick
07-24-2002 09:21:42
 Re: Quietubg Valve Nosie in reply to Greg, 07-23-2002 17:38:44
I would first check to make sure oil is getting up to the head. You could have something clogged. I assume you have adjusted the valves. Are any of the push rods bent?
