Jerking hydraulics
ken
07-20-2002 19:49:50
I have a 885 case tractor and the hydraulic system, or three point hitch when loaded it drops and catches and jerks back up.The heavier the load the faster it falls down and jerks back up.We checked the pressure and it has 2500 lbs.Took out the valve body cleaned it and did not see anything that looked bad, but that don't mean anything. Took out the piston and put new o rings on it and still the same thing. Do i need to change the valve body to a new one, it seems that is all that is left. Any help would mean a lot, it's very aggravating to try to use.
RobertTX
07-22-2002 10:06:51
 Re: jerking hydraulics in reply to ken , 07-20-2002 19:49:50
I have a CIH 585 that did that. I assume yours is a David Brown? If so, different tractors but basically the same type system. I found my problem to be the large o ring on the lift piston, sounds like you may have already replaced that. The thing I learned in all the taking apart is the the rapid jerk upwards to correct the drop means your pump and control valve are probably OK. It jerks up because your valve is sensing the drop and supplying the lift with a small shot from the pump to compensate. If it is not that big o ring, you may have a leak somewhere else. Possibly relief valve or I guess one of the lines could have cracked or developed a leaky fitting. Good luck, on the 585 it is not a fun job.
smotch
07-21-2002 21:07:45
Ken, I don't know allot about these tractors but if they have a control lever for setting your draft heavy or light does changing this help? If not the next thing that comes to mind would be to check linkage ajustments on the hitch.Just some thoughts that I hope may help you out .
KEN
07-22-2002 18:30:07
 Re: Re: jerking hydraulics in reply to smotch, 07-21-2002 21:07:45
It does have a selectomatic lever on it one is for depth control. It makes a little difference but not much.The problem started when it got to were it would not lift unless rev'ed up fast when idle down impleiment goes down would'nt stay up unless on high idle.Took to shop and they replaced the hydraulic pump.Brought home worked short time,pressure was low so i took rear end off and found an o ring blowed out where the metal line bolts to the pump. Put in new ring got pressure back to 2500 lbs.Now we have the jerking up and down.Also the lever that raises and lowers the plows will not stay down it has pressure pushing it back up to about middle ways.You have to hold it down for plows to stay down.We did take the valve body out and cleaned it but no difference.The piston o ring was changed also.Maybe one of those metal lines has a hole. I thank you for the help.
Mike
08-01-2002 09:47:09
 Re: Re: Re: jerking hydraulics in reply to KEN, 07-22-2002 18:30:07
Ken, Did you ever find out what was causing your poblem? I have a db 780 and its doing the same thing only it dosen't sound as bad as yours. Do you have clean fluid in it?
KEN
08-01-2002 13:52:17
 Re: Re: Re: Re: jerking hydraulics in reply to Mike, 08-01-2002 09:47:09
We have taken it all to peices twice and still have the same thing.Have changed everything but the valve body, took it apart can't see any problems.It must be in the vavles, but that is very costly just to try and not work.The valve body is about 1000 bucks.We are still trying though it's not useable in this condition.The pressure is leaking off somewhere, but the remotes are showing 2500lbs. So that leads me to think it's in the valves because the remotes are seperate from the control valves.
