David Brown 990 Owner's Manual
steve
07-19-2002 07:17:41
I recently acquired a David Brown 990 diesel engine tractor, and I need an owner's manual for it. I have learned the tractors were made from 1961 to 1979. I have a 1974. I see you can buy manuals for early or late models. I am assuming the 1974 is a late model, but does anyone know for sure at what year a 990 is called a late model?
Elmer
07-19-2002 15:21:28
 Re: David Brown 990 Owner's Manual in reply to steve, 07-19-2002 07:17:41
Look on the right side of the tractor up at the front. The model and serial number is stamped on the top of the front frame just ahead of the engine. It would actually be between the area of the radiator and the engine. Let me know what the number is and i can date it for you. I have manuals here. The difference between implematic and selectamatic is the hydraulic system.
steve
07-22-2002 10:43:18
 Re: Re: David Brown 990 Owner's Manual in reply to Elmer, 07-19-2002 15:21:28
The number on the frame is 9901863307. The 990 is obvious, and the 863307 means it is a 1974 model in my used tractor price guide. The 1 is between two vertical lines. What does that mean? Also, how do you know whether or not it is an implematic or selectimatic? Thanks for you help!
Peter
07-22-2002 18:42:17
 Re: Re: Re: David Brown 990 Owner's Manual in reply to steve, 07-22-2002 10:43:18
The Implematic tractors were painted red and had a round front. The Selectamatic tractors were white and had a more modern appearance. Your tractor is a Selectamatic.
