Steve, I tend to agree with Roger as there should be no hydraulic pressure to the interlocks when the control valves spools are in neutral. The following is just a shot in the dark as the hydraulic flow charts, except for neutral position, are not in my service manual so I am basically just guessing here, perhaps Roger can correct me. When you move the spool in the upper control valve to actuate the remotes you are closing off the pump return port to the sump, as well as, simultaneously opening the supply and return ports to the remotes. That means that your lower control valve has the same pump pressure as you are delivering to the remotes. If the lower control valve spool is leaking or out of neutral, the resulting pressure would tend to raise the eagle hitch piston since the upper control valve has the pump return passage port blocked. The double-acting and single-acting interlocks are identical except that the center port is open on the single-acting block and you have to install a pipe plug in there to use it on double-acting systems. This center port appears to be in communication with the sump via a passage in the control valves casting independent of the spool position. I was just wondering if some where along the line your upper and lower interlock blocks were swapped or the lower interlock block center port still has the plug. And even so would this cause the problem you are experiencing? Joe
