My C Case is almost done! *PIC*
Pete H
07-18-2002 23:52:11
third party image
Yippy! It�s been a long and many times frustrating 9 months, but I�m (we�re) almost done. All we have left are the decals, hitch, and hood. It should be completely done in two weeks for a pull at the Union Thresheree in Symco Wisconsin, which is our home pull.
This weekend we are heading to the Rosholt Thresheree for the first test pull, pulling in the 4500 lb class. We will finally get to see if all the hard work and $ pays off. The only thing modified on the motor is the head. It�s a high comp. head off a DC with new valves. I�m kind of interested to see if she�ll have enough power to turn the bigger tires in back.
I�ve got some pictures online of the process, but I�m missing the ones that show all the old paint removed with a wire wheel. That part took us a good 3 months. That was the worst part of all but we knew it had to be done in order to get a great finish.
If anyone is going to be in Rosholt or Symco stop by and say hello!
Pete H
shoe
07-19-2002 19:04:19
 Re: My C Case is almost done! *PIC* in reply to Pete H, 07-18-2002 23:52:11
You sure did a nice job on the old girl. That's
a project that you should be proud of for many
years to come. So what if it doesn't pull real
well, it's all for fun anyway, but I'll bet it's
right there with the rest of them in it's class.
Good job.
Dave_D
07-19-2002 08:09:38
Sure looks good! Nice pictures showing the history of the rebuild.
- Dave
RobertTX
07-19-2002 05:57:59
Looks great, especially the fenders. Also nice detail on the radiator. You should get a lot of attention at the show.
Dennis/Ohio
07-19-2002 04:52:17
Looks great.... After the wire wheel paint removal did you sand the bare metal? I wire wheeled the bottom of a car once but didn't sand it. Later I learned the paint would adhere better if I had scuffed it too. Good luck with your test pull, Dennis.....
Pete H
07-19-2002 10:27:03
 Re: Re: My C Case is almost done! *PIC* in reply to Dennis/Ohio, 07-19-2002 04:52:17
Nope, we didn't sand it after the wire brush. All we did was steam clean it and then wipe it down with acetone.
Also, we used a bit of an unusual paint sprayer when it came time to paint. Instead of a normal HVLP spray can, we used an air blow gun with a hose attached to the bottom of it, running into a paint can. It throws the paint out pretty fast almost in uneven small gobs (if that makes sense). It really gives the finish an old fashion texture. We call it a Foof gun.
Pete H
