The other guys are correct in their comments about the impulse. I would like to add that just "getting a spark" is not enough. Since the resistance across the spark plug gap increases with pressure as occurs during the compression stroke, the magneto must be capable of generating sufficient voltage to cross a gap much greater than the 0.030" spark plug gap at atmospheric conditions. As I remember the spec for the American Bosch magnetos is 5 mm (roughly 0.20") or about seven times the spark plug gap. A good magneto will exceed that. A hot Case base mount (CMA-4) will cross over a 3/4" gap sometimes at cranking or impulse speed and all the time at engine operating speed. I don't know how much voltage that is, but if we are ever standing around talking and I ask you to hold the end of a wire, be careful. (HA!) I think if people understood what a good magneto is capable of, there would be very few conversions to distributors. I came to learn these things after spending a day and a half hand cranking the first L I redid. The magneto would make a blue/orange spark on the spark plug, but I didn't realize that it was prpbably doing nothing with the plug in the engine at cranking pressure. To check your magneto, take a plug and bend back or break off the ground electrode. The magneto should be able to cross the gap from the center electrode to the plug body. A good magneto spark looks like a good hot gas flame, kind of a clear blue, no orange. Other things to check: Make sure your wires are seated fully in the nipples on the magneto cap. The ones on the Case magnetos are very deep and sometimes the rubber cover on the plug wire will prevent the wire from bottoming in the nipple. Some of the currently available wire sets have an end that is a little big and hard to make seat, push hard. Clean the points with a point file, then contact cleaner. The impulse should have a slightly loose feel to it. If it is dirty, greasy, gummy, rusty, it will not give the armature a good spin. Check the ground of the magneto housing to the tractor. It is possible to get some insulation from paint or grease. The female threads in the magneto are often corroded, so the mounting bolts are not necessarily a good ground connection. If all that fails, call me at 281 575 5665 (work) or email me.
