Help!! on 400 case diesel
Larry
07-18-2002 11:52:22
One more time, I cannot time pump to engine . Marks wont line up exactly. Not half out. Need help. No one will even respond?
Pat T
07-18-2002 18:28:49
 Re: Help!! on 400 case diesel in reply to Larry, 07-18-2002 11:52:22
Larry-
Check your e-mail and wait for it, 600kb worth.
Pat
Larry
07-18-2002 14:26:59
Do you have a I&T manual for your tractor. I was looking in mine about timing the 400,and there seems to be a serial number break in which there is two different settings on the crankshaft pulley timing. Prior to serial number 8104711 you need to set it at 26 degrees.After number 8104710 you need to set it at 27 degrees. If it's a 700 or 800 mtor it would be 31 degrees.
